12-19-2005 09:52 AM
12-04-2007 10:14 AM
12-04-2007 03:32 PM
05-31-2008 05:56 PM
06-02-2008 01:12 PM
06-02-2008 03:11 PM - edited 06-02-2008 03:12 PM
06-02-2008 03:32 PM
09-16-2008 11:30 AM
Make sure your baud rates match, in your parameter file in the RoboCylinder controller with your serial port on your PC. The sum check at the end can be a bit of a pain till you get it. I would suggest that you contact Peter Langus in Itasca, IL. He is very good with this stuff. (800) 944-0333. I am an IAI distributor for 19 years and Peter has been a good source for my customers. I have one that used the P-CON controller with Labview with no problems. The manuals on line are not exactly perfect. But Peter has more info that he can send to you. Hope this helps. Check out their web site also for the latest controllers. The RoboNet is very nice.
Jim Miller
11-21-2012 05:22 AM
Hi all,
I am planning to use an IAI robocylinder in a system which is controlled by CRIO/Labview.
As far as I know, there are no C-series drivers that I can use directly with the robocylinder.
Instead, I want to use the IAI controller ASEL, and C-series modules for digital I/O to communicate
with the ASEL robocylinder controller. I want to setup the ASEL such that the 5 positions I need can
be directly chosen by the DO lines of the C-module.
Is this a feasible way to do it or are there any recommendations on how to do it instead?
Thanks for your help!
11-21-2012 10:22 AM
I guess the email notifications keep working for years.
You should have no trouble using cRIO and digital module to move the Robocylinder. I imagine some of the Robocylinder setup software has changed in all this time. But the procedure is probably more or less the same.
Aside from the 5 outputs for positions, I believe you need at least one more for 'start'. I don't recall exactly, but I'm pretty sure I had to toggle both the position output and the 'start' output to get the cylinder moving.
Good luck with your project.
