02-26-2015 05:19 PM
Hi Crossrulz,blokk, sam ao
It's in the middle of the night but I was curious to see what you made for me.
It's all working fine, but the result is not what I expected. The file is tada2.txt.
When I compare with the old file I have I see
- The amount of samples is oke.
- The bits per sample is oke.
- The samplerate is oke. But the result is not what I expected.
I have the old txt-file (tada.txt) made years ago with a Windows 98 program that nowadays does not work anymore.
In the two attachments you can see the difference. I have no idea what to do, but there must be a connction because both are made of the same wav.
Do you have an idea?
Greetings, Peter
02-26-2015 11:42 PM
sorry, but i do not know what is the result what you expect. You have the LV vi so you can see what it does. You do not have the old program, so I cannot have any idea what way it worked. Maybe you should make a clear definition about the information you are willing to extract from wav files. Until this question is under defined, at least for me...
03-10-2015 04:59 PM
I'll try:
in the wav there is information.
I need that information as hex or binary so I can send it to a microprocessor and I can play that file and hear the wav.
It's not for playing the music but for sounds in programs I use ( one phrase of a song or something like that).
Greetings, Peter
03-10-2015 05:07 PM
03-13-2015 12:34 AM
I stop for a while with this issue because I'm not sure Laview caan solve my problem.
Maybe you hear of me in some weeks.
Thanks for all your help.
Peter
03-13-2015 12:36 AM - edited 03-13-2015 12:38 AM
vi
