Labview doesn't recognize the 4200-SCS
I am a student in an engineering school and I started working with labview.
I have to develop a labview program in order to control the 4200-SCS. I downloaded the drivers from tektronix website and when I try to run the example given with the drivers, I have this message: " ERROR: KI 4200 not detected. This program will be terminated. Make sure that 4200 is powered on, connected to GPIB bus, KXCI is running, and correct GPIB address is indicated". I verified what it said but everything is correctly connected.
(4,094 Views)
Please attach your code so we can look at it to ensure you're properly initializing the instrument.
CLD | CTD
(4,091 Views)
This is not my code, but an example available with  the drivers which is supposed to work if connected to the 4200-SCS properly.
I join the .llb where you can find this example. it is called "KI4200.vi"
(4,083 Views)
Hi Joris,
Are you able to communicate with you instrument from MAX?
Why Can't I Communicate with My GPIB Instrument?
M-Junior
(4,007 Views)
I have a problem with the write fonction but i'm sure that I have the correct GPIB address.
(3,986 Views)
Problem solved!
The problem came from the GPIB-USB cable. I changed it and everything went perfect.
(3,980 Views)
hello, what type gpib-usb cable did you use for you tool?
(1,026 Views)
