01-26-2015 01:09 PM - edited 01-26-2015 01:11 PM
i am developing an application to acquire images from a camera link device, and then process the frames in different loops that perform contour and particle analysis in different regions of interest.
For certain reason i am getting a labview crash almoust every two or three minutes of execution, i dont know why yet.
Does anyone knows something about the screenshot attached?
01-26-2015 02:47 PM
actually I am getting these three different errors when labview crash, please see doc attached.
01-26-2015 03:00 PM
Since you are using 32 bit LV, one thought is to check the RAM usage in Resource Manager. Sometimes I get the "Not enough memory to complete this operation" and sometimes I get crashes at whatever code doesn't complete. It depends, I think, on how fast the program gets to the 3 gb limit.
01-26-2015 08:34 PM
Ah, the old "Sorry for the Inconvenience" crash. This happens during development, not during execution, right? These are "hidden features" (a.k.a. "bugs") somewhere deep inside LabVIEW. In LabVIEW 2011, I found one related to Network Streams -- if I moved a wire on the Block Diagram, I could (reproducibly) cause such a crash. I believe NI was able to find/fix this by the next release.
The next time one happens, try and isolate what you were doing, and see if you can reproduce the crash. If so, give NI a call and send them the code so they can eliminate the problem. [Ah, I should have asked, What Version of LabVIEW are you running? I hope it is not LabVIEW 2011 ... This might be a problem that has been corrected in a later release ...]
