10-13-2014 01:59 AM
Hi all,
I have created a Project and have a main vi which works fine in the development environment. When I try to build exe for the same, LabVIEW crashes. I dont get it why. If anyone could help on this, you are welcome.
LabVIEW version:2013, 64 bit
Prabhu
Solved! Go to Solution.
10-13-2014 02:27 AM - edited 10-13-2014 02:27 AM
10-13-2014 02:46 AM
Can you share the image of your project i.e. all the componenet which is being added to project? The way you are doing also matters
10-13-2014 03:35 AM
Thanks Ranjeet. I got that to work, by marking remove unused files from project libraries. I think the problem was about memory.
Prabhu
10-13-2014 05:10 AM
GREAT !!!!
Then mark your reply as answer..This might be useful to someone in future
08-05-2020 03:13 AM
Labview kept crashing when I tried to build a PPL from an Actor Framework project in LV2018. The problem was fixed for me by doing the opposite, I unchecked "Remove Unused members of project libraries".
If building a PPL I would also recommend dragging any external lvlib files into the lvlib that you want to create the PPL from and then back out again, then do a mass compile of the project (Tools > Advanced > Mass Compile). This uncovered many broken VIs and unused VIs that needed to disconnected from libraries. Now my PPL finally builds after trying to debug this for weeks
