Labview claims invalid VCCO level on IO module
On my PC both our company's IO module and the NI 6581 module show up correctly in the IO Module Properties dialog.
On our PXI machine in the lab, LabVIEW complains that both modules have invalid VCCO levels specified (presumably in the .tbc)
I have checked the .tbc for both IO modules, and they contain valid levels. I'm starting to believe there might be some software problem, but I can't find any clues.
//Olof
(2,678 Views)
Accepted by topic author OlofK
Could you set the regional OS settings to english - '.' as decimal point or change LabVIEW decimal point settings?
Example: 10.0 could be read as 10,0 which is invalid.
(2,664 Views)
Works fine. However, changing the . to , in the configuration file does not work
(2,659 Views)
Yes, I believe you can only change ',' to '.' and not the other way round.
(2,657 Views)
