12-07-2013 05:45 AM
Hello
I want to communicate my modbus compatible devices with labview..
And therefore i need guidance about the library and software uses for that operation.
How can i communicate my devices with Labview.
Please tell me ....
12-07-2013 06:21 AM
On website they are writing that: In the LabVIEW Project window, right-click My Computer and select New»I/O Server, but i have no that option..
Now what to do ?
12-07-2013 09:56 AM
On what website? A search on NI's site says to use either DSC (an add-on module you must purchase) or the Modbus library.
12-24-2013 06:00 AM
i found from NI website :"http://www.ni.com/white-paper/13911/en/"
i have already intalled Visa4.5.
then what should do ?
12-24-2013 06:39 AM
That white paper is using the DSC toolkit, which is an add-on. I suggest using the NI Modbus library that Dennis linked to earlier.
12-25-2013 05:26 AM
i understand that but..
My poject is:
I have home made RS-485(2-wire) compatible modbus protocol supported relay card.
Its address is (41302) and slave ID is (11).
this whole word (41302) has its bitwise relay..
and i want to operate it from labview as individual switch for each relay.
This is my target..
So please help me for this..
If i'm sucssed in this project then i can use Labview in my another project..
12-25-2013 10:23 AM
So, what happens when you use the functions from the modbus library? What functions are you using? What settings? What errors do you get?
Since this is a homegrown modbus device, I would strongly suggest trying some commercial modbus program to help isolate any problems to the hardware or software.
12-25-2013 11:38 PM
I have already tested my relay card with Modscan software and it's alright.
I'm able to on/off relay from modscan.
And now I want to start working with Labview, I have done only internal program program but not work with external devices through COM port.
So I don't know how to start.
So please help me step wise..
How to start from beginning..
I know how modbus protocol works..
