12-31-2009 10:21 AM - edited 12-31-2009 10:25 AM
Hi Guys:
i have two question about LV ui design:
Referring to application build by LV :
1 How to hide the menu bar in runing mode
2 How to change to title, i mean , usually the title of the application window is "xxx.vi " , can i change it?
thanks
Solved! Go to Solution.
12-31-2009 10:26 AM
While building exe we generally use main VI as Startup VI
Open this VI goto VI properties, goto Windows Appearance and select Dialog option.
And in the same window you have option "SAME AS VI NAME" , uncheck that option and give the name which you want to have when program is running.
Hope this solves your problem
12-31-2009 10:41 AM
12-31-2009 10:49 AM
12-31-2009 10:52 AM
