Labview Robotics Starter Kit 2.0 VI errors
I am working on a code to conrol the DaNI robot from the starter kit 2.0 with the keyboard arrows.
I am getting a few errors with my VI all FPGA related I think. Here's the list of errors:
1)  NI_Robotics_Starter Kit Host_9632_2.0lvclass:Open FPGA Ref_No Run.vi
--> Open FPGA VI Reference: target support for selected FPGA device is not installed
--> You have connected two terminals of different types
2)  NI_Robotics_Starter Kit Host_9632_2.0lvclass:Initialize Starter Kit 2.0 (sbRIO-9632).vi
--> LABVIEW Class Method SubVI `NI_Robotics_Starter Kit Host_FPGA_2.0lvclass:Initialize Starter Kit 2.0 (sbRIO-9632).vi`: One or more of the set of VIs that this dynamic dispath subVI or property item may call are broken
3)  NI_Robotics_Starter Kit Host_FPGA_2.0lvclass:Initialize FPGA Starter Kit Host.vi
--> LABVIEW Class Method SubVI `NI_Robotics_Starter Kit Host_FPGA_2.0lvclass:Open FPGA Ref_No Run.vi`: One or more of the set of VIs that this dynamic dispath subVI or property item may call are broken
From thoses errors I assume that I didnt install the FPGA module correctly but I don't understand how. ( I didn't edit the Starter Kit subVIs)
I installed Labview 2015, robotics module, FPGA module, myRIO sofware bundle, Simulation module, mathscript RT module and Vision development module.
Is there a specific order I need to install them in or did I miss a module?
Thanks for any help
MortZxD
(3,119 Views)
hey mortzxd,
This error could be because the FPGA reference has the incorrect name. looking at your vi as well I believe this loop will iterate only once. Do you want this?
Alex
(3,006 Views)
