02-25-2013 10:09 AM - edited 02-25-2013 10:13 AM
Hi
I am a final year student working on a project.
I want to make a vi which will measure two readings of the data such that the first reading is the initial reading and the second reading is after a certain period of time.
Basically I want to measure fuel flow using a strain gauge. The concept is that a small fuel tank is fitted on the strain gauge. At first the fuel tank will be full (note: this will be the first reading) and after 60 Seconds there will be a decrease in weight of the fuel tank due to fuel consumption (note: this will be the second reading).
I want to subtract the final reading from the initial reading and divide the answer by 60.
Please tell me how to do this.
Thank you.
The hardware I am using is chassis cdaq9172 and Ni 9129.
02-25-2013 10:14 AM
Let's start from the beginning. Do you know how to take a measurement? I see you are using a strain gauge, but how are you reading it? DAQ? DMM?
02-25-2013 11:55 AM
well i am using a four wire strain gauge and interfacing it using ni9219 in cdaq 9178 chassis. I am using a DAQ.
Thank you very much for your reply. I am a begineer.
02-25-2013 12:23 PM
I would setup the DAQmx task to sample every 100ms for 1 minute (600 samples). Tell the task to run, wait the 60 seconds, read the data, do your math on the 0 and 599 indecies.
02-25-2013 12:27 PM
Will you please tell me how to do so?
02-25-2013 01:47 PM - edited 02-25-2013 01:48 PM
02-25-2013 09:36 PM
Thank you very much. I really appreciate your help.
Thanks a a lot.
03-02-2013 11:08 PM
Hello crossrulz
I have tried to make this in Labview 2009 but I am finding it hard to make the VI as I am not professional in using Labview 2009.
CAn you please explain further so that I can make this VI in labview 2009.
