02-22-2008 01:26 AM - edited 02-22-2008 01:26 AM
PDA applications you build with the PDA Module are resolution aware, which means you do not have to do anything specific to support high-resolution displays (VGA) on Windows Mobile targets if the Windows Mobile target has a high-resolution screen.
The PDA Module supports Windows Mobile devices with high-resolution display and low-resolution displa
02-22-2008 10:49 AM
02-24-2008 05:41 AM
Thanks Stanley,
By refering to the LabVIew PDA Module's video tutorial by ni.com was mention the capable PDA such as
HP, Compact, Dell, Palm and Sony were available.
(Slide-3) http://www.ni.com/swf/presentation/us/labview/lvpda/default.htm
My Target PDA phone was the HP iPAQ 600 Business Navigator- Models
http://h10010.www1.hp.com/wwpc/sg/en/ho/WF06a/1090709-1113753-1113753-1113753-1117925-80593313.html
Can you please rashly let me know the possibility of this model's spec. if the LabView PDA module applying on this HP PDA phone?
02-25-2008 11:12 AM - edited 02-25-2008 11:12 AM
02-28-2008 07:30 PM
Thanks Stanley,
I am always understand both advantages as the Labview PDA Module is for mobility convernient and the Labview on Desktop is for performance required.
Perhaps HP iPAQ 600 is really work up with LabView PDA Module. 🙂 Its a perfect PDA Phone that i had been survey.
03-07-2008 05:47 PM
08-27-2009 08:44 AM
teresadmij, did you get the T830 to work with the NI USB 6008???
Did the intel processor or the display resolution of 240 by 240 make any problems?
Plus someone wrote that LabVIEW was working fine with the Samsung Blackjack.
Can someone tell me if thats the case too in connection with the NI USB 6008?
Cause i did not find the Blackjack smartphone to be host capabilities.
I am frustrated here switching phones via Ebay unti l i get my applicationto work.
Now i have to switch to the old T830 with Windows Mobile 5 cause windows mobile 6 is not
supported yet by the Daqmx Basedriver so i cant use all the new phones either as they come with WM 6.
08-28-2009 05:02 PM
Does the mobile device have USB Host Support?
Flash
08-28-2009 05:33 PM
08-28-2009 06:10 PM
Hello, yes the fujitsu siemens t830 has usb host.
but i dont know if the Mobile module will suit the 240 by 240 resolution of the display.
kind regards
