Labview Image Processing
I need to develope a program for extracting ROI of an image? How to do that?
Steps: Capture image from a system, Extract the region of interest,Select a row approximately in the middle of the membrane area of the image,Determine the intensities at all the points across the membrane, Plot a graph of the intensities across the row (the line profile). Please help me to do this. I am new in image processing. I am attaching front panel view of this.. I am not sure about whether this is correct or not. What is the block diagram for this system?
Message 1 of 21
(5,464 Views)
what do u want you want to achieve?
whats your input ?
what kind of image?
Is your ROI is fixed or you will select during run time?
Find the attached example
Message 2 of 21
(5,444 Views)
My input is an image (actually image path). It is an image taken by monochrome camera. From this image I need to select a row approximately in the middle of the membrane area. From that determine the intensities at all the points across the membrane. Then plot a graph of the intensities across the row(the line profile). I will select the ROI durng the run time. it is not fixed
Message 3 of 21
(5,434 Views)
If Possible share the source code you tried and the sample image.
Message 4 of 21
(5,431 Views)
- You can check the inbuilt examples: This example shows how to use the display tools to draw a line on the window that displays an image and get the pixel values of the image along that line (line profile).
- To navigate to examples: open LabVIEW and navigate to Help » Find Examples... » Toolkits and Modules.
uday
Message 5 of 21
(5,428 Views)
I am attaching the front panel view, image etc.
Message 6 of 21
(5,426 Views)
Message 7 of 21
(5,402 Views)
Hope this will help you.
Message 8 of 21
(5,391 Views)
what is this module(attached 11)? and i need to use all the controllers and indicators of that front panel i am attached previously. I am checking this current diagram now
Message 9 of 21
(5,384 Views)
-I believe you definitely need to learn about LabVIEW. Please try below free online material :
Start with below links to learn about LabVIEW programming
NI Learning Center
NI Getting Started
-LabVEW Basics
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
LabVIEW Graphical Programming Course
-It is property node for the Image indicator.
uday
Message 10 of 21
(5,378 Views)
