Labview Image Analysis nor working on a exe file
hi,
I have a labview program that uses IMAQ toolbox and works quite well. But when i make an exe file and run it on a computer that has Labview run time engine installed, i get errors that the Vision_Development_Module is not found and the sub VIs cant be used.
Could someone tell me what the problem could be and how i can solve this.
(2,857 Views)
Accepted by topic author krupatechnospartan
You also need the Vision Runtime Engine installed.
GCentral
(2,851 Views)
I have installed NI Vision Run TIme 2013 SP1 in evaluation mode. It still doesnt work. Do i need something else? It reports missing objects again.
(2,678 Views)
What version of LabVIEW are you using?  If you are using LabVIEW 2014, then you need the RunTime Engine for LabVIEW 2014 and the Vision Runtime 2014.
This would be a lot easier for you if you just build an installer for your application.
GCentral
(2,670 Views)
