07-06-2015 12:07 AM
Hi. I'm Kitaek.
I am studying Labview for my research.
In my measurement, the sample rate is 125KHz.
I want to get average value in every new 100 samples.
Therefore, I want to get mean value of 1~100th samples and store this mean value. Call it average1.
Next, I want to get mean value of 101~200th samples and store this mean value, Call it average2.
I don't know how I get I want.
Kitaek.
Solved! Go to Solution.
07-06-2015 12:41 AM
07-06-2015 01:16 AM
Thanks a lot Blokk.
But I'm very unfamiliar to Labview.
So if you don't mind, would you attach .vi file that is same as the image you attached.
That will be very helpful for me.
Thanks again,
Kitaek.
07-06-2015 01:20 AM
The png file which I have attached, includes a VI. Save it and drag&drop it into an empty block diagram:
http://www.ni.com/tutorial/9330/en/
If you are a beginner, you can advance through the online teaching material Core1-2:
https://decibel.ni.com/content/docs/DOC-40451
See the links under "Looking for free training"
07-06-2015 01:46 AM
You're very kind. Thank you.
But the Labview I am using has the version 2009.
So I can't snippet your image.
Would you let me know how I can do.
Kitaek.
07-06-2015 02:04 AM
I have attached the 2009 version. Note that, in this old LV version, there is no conditional terminal for autoindexing, so a shift register is used to build the array.
However, I would not use this particular example for your case. If you tell me what kind of hardware you use (number of channels, rate, etc...), I can give a better example including DAQmx VIs and showing how to use the producer/consumer design pattern + data logging into tdms file.
10-21-2020 12:45 AM
Could you please explain to me how your vi works?
10-21-2020 01:20 AM - edited 10-21-2020 01:22 AM
