NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
simon76
Labview GUI interface usb/virtual serial port from pic18f2550
I doing project replace the hardware using pic. Since the GUI is labview interface, i not intention to switch to other software.
By modify the pic code from the cdc-emulator example,i able to do the serial read/write using hyperterminal and vb.net but not with the labview.
It prompt out the error
Error -1073807330 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi
Possible reason(s):
VISA:  (Hex 0xBFFF001E) The specified state of the attribute is not valid, or is not supported as defined by the resource.
Look like i fail to configure the COM Port which is visualize as valid com port in device manager and i open the MAX, there's error show as pic attach.
I already try to create new driver .inf from the driver lizard and install it but still no luck.
I've been visit the microchip forum and view other ppl solution and look like they don't face this problem "Error configure port".
So, anyone can help me to solve this problem??
Attach also the main.c for the pic programming. I newbie in pic programming, possible the code is not completed.
thanks and regards,
Simon
Member
dy_naco
Re: Labview GUI interface usb/virtual serial port from pic18f2550
HI all.
I meet the same error and need the solution, even some hint or direction will be helpfull
I have made composite device based on RoDeNtJe project ( dual cdc) based on 18f4553
it work well in hyperterminal. unfortunately i changed 3 PC with this project so:
it works perfect on winxp
it works on win7 32bits  ( limitation - transmitting for only 3 bytes at a time)
it works same on win7 64bits up to some day.  then the multiply error  (-1073807360)  start appear.
i think it happened after the USBSER.sys have been updated by windows.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
