02-17-2009 10:00 AM
Hey Milky,
The circled blocks in grey are just delays in the code. They're not always necessary depending on the hardware. The yellow blocks are index arrays that grab particular NodeIDs for you to specify which ID feeds into the Read Vis. The simplified version of the VIs should work fine for you and I recommend using it since it's successfully getting your data.
02-18-2009 09:05 AM
Thanks David for explaining 🙂
I've attached my vi file. This is how I intend to design my GUI but I haven't figure out how should I connect the graphs waveform to my sensors on MTS400 and how should I connect my nodes to write to a spreadsheet in my block diagram... Can you please help to show me how?
Kim
02-18-2009 09:38 AM
Hey Milky,
What data from the clusters are you wanting to write to the spredsheet? All of it? Just Light, just temperature, just humidity?
02-18-2009 06:19 PM
02-18-2009 08:34 PM
02-20-2009 01:20 AM
Hey David,
I'm so excited tat I did it! I could monitor my waveform chart already as attached. 🙂
I'm still trying to figure out how to make the time on my waveform chart to follow the time stamp on my node. Can you teach me?
I still haven't figure out how to write the data frm my nodes to a spreadsheet... Pls show me how can I do it...
Kim
02-20-2009 01:57 PM
Hey Kim,
If you're only wanting to write the four graphs you're taking then writing to the spreadsheet is simple. See attached photo.
02-20-2009 08:56 PM
David, your drawing is so much simpler than mine. Can you please send me your vi file? There are some features that I don't understand without the context help in JPG file.
Thanks!
Kim
02-20-2009 09:41 PM
Hi David,
I tried to connect the write to spreadsheet function but I get the error as attached. How can I fix it?
Kim
02-21-2009 11:59 AM
