06-17-2014 03:29 PM
Hi - when running a VI in Labview for an extended period of time, I would like to set my hardware into a safe mode if the LabView license server goes down. Is there a way to detect this in the VI? And if so, do I have time to issue one last set of commands before LabView stops working?
THanks
06-17-2014 05:59 PM
Build the exe! You should not be running dependant on continuous connections to servers. An exe runs in the unlicensed LabVIEW RTE (Some tool-kits and addons have additional requirements)
Now as far as I know, the IDE queries the VLS at launch or when dynamically loading licensed toolkits and addons. I don't think there are periodic revalidations for licenses that do not expire. (And for those that do expire my experience is they are also only queried at launch)
- without specifics I can't really answer and, you should be contacting the License issuer directly since, any info I give you should not be the sole source for you adopting practices which may or may not comply with the terms of your license agreements.
