03-30-2017 05:46 AM
How do you tell if Labview, DAQ Cards and Drivers are compatible w one another? In other words if I developed in Labview 5 ( exaggerated of course) and create an exe can I use it with a PXI-6229 and its drivers bought in 2017 ?? Are there 3 different spec sheets?
Thanks..
03-30-2017 06:04 AM - edited 03-30-2017 06:12 AM
Hi Clint,
there are compatibility charts for LabVIEW vs. DAQmx. And with each DAQmx version there is a document describing which hardware is supported…
In case of trouble: phone the NI support!
And when upgrading from LV5 you surely want to change from TraditionalDAQ to DAQmx…
03-30-2017 09:05 AM - edited 03-30-2017 09:06 AM
Thanks ..perfect.
