02-27-2015 10:50 AM
02-27-2015 12:17 PM
02-27-2015 01:28 PM
If you have LabVIEW for Linux you can give it a try with Ubuntu OS installed on the BeagleBone Black.
02-27-2015 02:43 PM
02-28-2015 10:40 AM
Here's a link to a Community discussion regarding the possibility to execute LabVIEW Real-Time on a ARMv7.
03-01-2015 06:42 AM
03-02-2015 04:40 AM - edited 03-02-2015 04:44 AM
It would have to be an x86 board with Linux support. And I'm not aware of any board like that within the price range you indicate.
The other option in the thread from Michael definitely will fall out of that price range even if you forget the significant effort to port NI Linux RT to your target, since you have to calculate the LabVIEW runtime license in.
03-02-2015 05:17 AM
03-02-2015 05:39 AM
There's a project to build a compiler which will compile LV code for the Arduino. They haven't released a final price or release date, but they were talking about March and something on the order of 50-500$ for the dev license. It should also be clear that this will have some limits, but it looks fairly promising - http://www.tsxperts.com/arduino-compatible-compiler-for-labview/
03-02-2015 09:03 AM
@therealjohndoe77 wrote:
what about Edison's breakout kit or the Minnowboard? both have x86 architecture with Intel's Edison and Atom processor respectively
Intel Edison would get close to the indicated price range as you have to add some carrier board before you can even think about using it and seems to have Linux support, although the Yocto embedded suite, which may be different enough to cause some problems for a seemless operation. The Minnowboard seems to be far beyond the indicated price limit.
