10-02-2006 06:33 PM
10-02-2006 10:30 PM
10-03-2006 01:04 AM
Hello all,
I have manually uninstalled all NI components inclusive toolkits, MAX etc. But to uninstall everything, I had to first abort all NI Tasks. Other vice I was not able to uninstall MAX. Then I used msiBlast.exe but msiBlast.exe couldn’t find further NI Software to uninstall.
(I have tested msiBlast.exe before manually uninstalling everything and it found a lot of NI Software)
After that, I have used a registry cleaner to clean the whole registry. The registry cleaner found a lot of NI- registry keys to remove. But I’m not sure if he really has removed all NI keys…
Anyway I am not sure that this Problem is only caused by a “bad registry key”.
My problem only exists when I boot up my PC and nidevmon.exe and nimxs.exe are not running correctly…
I always have to reboot the computer till the nidevmon.exe is running correctly, then I know, that I can start LabVIEW, MAX etc…
Today I had only to reboot twice…
When nidevmo.exe appears in the Taskbar I can start and quit LabVIEW and MAX as much as I like… But I don’t like to run my computer 365 days a year…
By the way I have also checked the hard disk for errors, but there were no errors…
Martin
CLD
10-14-2006 11:42 AM
Hello Martin,
did you find a solution for this behaviour in the meantime - I'm encountering a similar problem (NI-MAX will not start when LabWindows/CVI V8.0.1 is installed and the Vision Dev. Module 8.2 is installed). Horrible - I'm installing the SW now for more than a week (and remove it completely) - this is really a nightmare!
By the way - I'm using a DUAL CORE Atholn 64 X2 4800+.
But I do not think, this is the reason, as my system used to work with an older Vision SW. But this does not help me no longer - even ealier SW-Versions will cause the same problem.
Thomas
10-15-2006 03:40 PM
10-27-2006 01:12 AM - edited 10-27-2006 01:12 AM
Message Edited by mc-hase on 10-27-2006 01:13 AM
Message Edited by mc-hase on 10-27-2006 01:14 AM
