06-14-2006 02:37 PM
Well I’m glad to hear that you are up and running again. I’m slightly uncomfortable with the problem sort of resolving itself and think that you might benefit from a clean-wipe of NI Software combined with a fresh reinstall (remember that MSI installed programs are meant to go through uninstallation as opposed to deleting directly from disk), however given the time that it might take I completely understand if your happy using LabVIEW now that it runs.
Feel free to let us know if you have any additional questions and if you do need to rid your system of any trace of NI software please visit www.ni.com/support to let us know.
Thanks again for posting to the discussion forums – have a great afternoon!
06-15-2006 12:46 AM
06-15-2006 01:54 PM
My apologies, I believe that I may have been a little unclear in an earlier post. It is entirely possible to remove any trace of NI software from your computer by going thorough the normal uninstallation procedure which requires users to go through the add/remove software wizards in the Control Panel and remove each software item individually as needed. In unusual event that these steps fail, we can sometimes guide users though ‘manually’ deleting the software, but there’s no exact science to it so we request that users contact us directly for help with that.
I apologize for any confusion on that, and I’m glad to hear that you are up and running!
06-15-2006 02:03 PM
Just a shot in the dark here, have you tried upgrading DAQmx from 8.0 to 8.1?
06-24-2006 07:47 PM
06-26-2006 09:13 AM
Good morning,
Yes, you can configure the services to run “manually”. We really urge you to avoid modifying the registry unless you really have to (we actually really caution you about changing the NI Services as well). To configure the services, open MS Control Panel, and open “Administrator Tools->Services”. Find the services you are interested in (the NI ones either start with “NI” or “National Instruments”), and right click to select “Properties”. From here, change the “startup type” to “Manual”.
I hope this helps-
07-07-2006 04:38 PM
07-10-2006 04:44 PM
Hello antennaguy,
Out of curiosity, have you worked with an engineer here on your problem?
In any event, the issue you describe has been reported and is being
investigated. Unfortunately, as far as I know there's no workaround other
than the one proposed.
Sorry for the trouble, let us know if you have any further questions on this issue by replying to this message, or for a new or unrelated issue please feel free to start a new thread. Thanks a bunch,
07-10-2006 04:49 PM
09-29-2006 06:49 AM
Hello all,
I have got the same problem with my LabVIEW 8.0.1....
Sometimes LabVIEW & MAX are hanging on startup…
I have got uninstalled everything (msiBlast.exe) cleaned the whole registry etc. But there was still the same Problem after reinstalling and mass-compiling- that sometimes LabVIEW & MAX don’t start correctly.
I have uninstalled everything a second time and just installed the 8.0 version (Tipp from NI-Support-Switzerland) and it’s still the same.
Sometimes LabVIEW starts after booting up the PC and sometimes it doesn’t start correctly. It always stops on “Beende Initialisierung”( Finishing Initialization)…
But if LabVIEW doesn’t starts correctly => MAX also doesn’t start! (There is just the start- picture from MAX)…
As far as I know, LabVIEW and MAX only start correctly if the “NI- Gerätemonitor” => nidevmon.exe is running correctly. That means that the Icon is visible in the taskbar.
When LabVIEW and MAX aren’t starting, nidevmo.exe is listed in the Task manager but the Icon is not visible in the Taskbar…
So I think the problem has something to do with a “NI-Task” which causes other task to “not running”
Martin
