05-10-2006 08:32 PM
05-11-2006 12:05 AM
05-11-2006 11:04 PM
05-12-2006 05:04 PM - edited 05-12-2006 05:04 PM
I would suggest that you either call/email National Instruments after creating a service request at www.ni.com/ask. We might be able to help you in cleaning your system.
Ankita Agarwal
Message Edited by Ankita on 05-12-2006 05:05 PM
05-13-2006 01:51 PM
06-11-2006 04:13 PM
06-12-2006 03:28 PM
Woah there! Let’s take a step back before we take drastic measures…..
First of all, does your Laptop meet all of the minimum requirements of the install of LabVIEW? Do you have sufficient RAM, do you have a supported OS, and do you have a capable video driver? All of these things make a difference! Additionally, there is a way to set the NI services (or any service for that matter) to run when needed as opposed to automatically running on startup. To do this, open the Windows Control Panel, and click on “Administrative Tools” and open “Services”. From here you can start and stop services, as well as configure them to run in “manual” mode which will start them only as needed.
There should never be a problem with uninstalling NI
Software due to NI services running. The
proper way to uninstall LabVIEW is to first shut down all NI programs you have
open. Then, go to control
panel->add/remove programs->national instruments software and choose “change”. From here you can uninstall LabVIEW by
clicking on it and selecting “remove”.
Installing 8.0.1 should have had no effect on the NI services or LabVIEW. Did you reboot and mass compile the
It is entirely possible that for some reason one of the NI services is hanging, or behaving poorly. I think you were on the right track with starting debugging from that point. We could also try to determine which exact service is causing problems, then determine which software that service installed with and troubleshoot from there.
I assure you that many people are running with all sorts of NI software combinations on their machines without these problems. If there is some problem with an NI service on your machine, installing a new version of LabVIEW might not make a difference anyway. I do apologize that this has been causing you problems, and I thank you for the debugging completed so far. I hope this information proves useful -- please let us know how things go!
06-13-2006 12:19 AM
06-13-2006 01:52 PM - edited 06-13-2006 01:52 PM
Humm..... Interesting problem, and I'm sorry that its one
that you are experiencing!
I'm pretty certain that though the manual file renaming, repairs, and
reinstalls that the state of NI software on your computer is very unstable.
You mention that msiblast and the registry are not total solutions. This
is not completely unexpected, and we do have additional steps that you can take
to remove the software. Because of software piracy issues we do not
publish them, but your AE that you contacted in May should be aware of the
steps you need to take. Using the Service Request that you had used
before, give us a call at 1-866-275-6964 to speak with the AE you contacted
personally and ask about this.
I suppose we could supply you with those missing DLLs and their location to appease LabVIEW, but I think this could have dangerous versioning side-effects so let’s start with reinstalling and getting LabVIEW to open a VI first.
Again, sorry that this has been a problem, please let me know how things go.
Message Edited by Travis M. on 06-13-2006 01:52 PM
06-13-2006 03:49 PM
