I have some LV-programs (Labview 7.1) and I would like to start this program as an executable, but I didn't find any information how to do this with LV7.1. Could you give some information
Go to your tools menu and see if you have the option for "Build Application or Shared Library". If you have this listed, then you can use the on-line help and open the topics under "stand-alone applications". If you don't have this listed under the tools menu, then you will need to buy the app builder from NI. It is not included with the base or full versions of LabVIEW. It is only included with the pro version.
