Labview 2011 wsn add new elements to radio messages
how can I add new elements to the Labview WSN messages radio?. When I add this object to the block diagram, it contains only the default values (network status , sample interval, send user message, received user messages and send debug messages). For example I want to send the value of the channel AI3, How do I add this item to the available elements in the radius message? please see the picture.
(2,565 Views)
Hello AmFlores;
What LabVIEW Version and WSN Pioneer Version are you using?
Starting in LabVIEW 2011 the radio nodes no longer work for inputs and  outputs; all values are now transfered via Shared Variables as seen in the image below
This makes communication easier, since it is handled by the variable engine, and you can still use
the radio messages to create personalized messages and access the network status.
Why do DO in Radio Messages Node no longer Work in LabVIEW WSN 2011?
Hope this info helps.
(2,452 Views)
