02-19-2015 03:50 AM
I agree with you about the VCP being easier to use. I should have linked to that.
My applications are often small custom boards with onboard 8 bitmicrocontroller connecting to USB via some FTDI chip.
When you say "Your choice also prevents someone from using an existing instrument driver" do you mean for applications where the target is more sophisticated than a simple micro, or where it already has available drivers ?
I'm interested in hearing if there are better options than the ftdi chip for my simple custom USB comms scenarios.
I'm also keen to know what other options are out there for easily interfacing LV to small low cost microprocessor boards via USB....without writing the USB interface in the micro itself.
carloman
02-19-2015 07:25 AM
