07-03-2005 02:53 PM
07-04-2005 01:02 AM
Does this happen whenever you use the string to number VI (can you reproduce this in an empty VI)?
Are you sure it happened because of that VI and not because of something else that is happening in the VI at the same time?
Can you cut down pieces of the code and still get the error? Can you post a small example?
Which PDA\LV are you using?
Can you write some more details about your app (does it do anything else other than serial comm)?
