LabView 8.5 How to Adjust Pressure Scale?
Hello All,
Complete newbie to LabVIEW and need help. We are running LabVIEW 8.5 on a H20 pressure stand and had to replace a high pressure sensor, after install the pressure readout on the screen shows -19 psi. It should be zero with the test stand not running. How can I zero the display out or set an offset? The sensor came calibrated from the manufacturer and was checked by an outside calibration house and passed.
I've opened up a project which I think is the settings for the machine but can't find any calibration settings.
Any help would be appreciated.
(2,512 Views)
 Hi  fbergski
Are you able to attach your code?
Have you verified that the voltage readout from the transducer is giving the correct value outside of software?
Ingram | CLA
(2,456 Views)
Where is this code located? Totally new to LabVIEW. I'll check voltages this morning.
(2,450 Views)
Input voltage per spec, next I called the sensor company and they sent me a procedure to zero the sensor, worked somewhat. By doing that the stand came back to life, not sure what I did but it worked. Still need to adjust -10psi out of the software.
(2,433 Views)
