Hi JHA,
For LabVIEW 3.1.1 you will need Application Builder 3.1.
Do you get the issue when building a very simple VI (e.g. add two numbers)? If you do, there might be an issue with the Application Builder and you might want to reinstall it.
If you don't get the error with the simple VI, you might be missing resources needed for the VI you are trying to build. Make sure that all support files are included when building (dll's, dynamically called VI's, other files).
Has anyone else seen this issue with LabVIEW 3.1.1 and solved it differently?
- Philip Courtois, Thinkbot Solutions
