LabView 2014 - DSC module with Ethernet Modbus: Error 56
Sorry,
I try to connect modbus by Labview 2014 DSC module like this figure, and it occurred error code 56 at "Read Input Registers",
I have look for many soluctions, but still fail, can someone help me? thank you very much!
(2,926 Views)
Did you confirm the address and port of your slave device is correct? Also, is your device a modbus master device or slave device?
I suggest you to read the help first, and then run the corresponding example
You can run the two example to test if the modbus function is OK. Then you can come back to test your third party device.
(2,894 Views)
