11-25-2014 07:39 PM - edited 11-25-2014 07:39 PM
Hello folks,
I'm wondering if anyone has seen this problem before.
So, when I click on any of LabVIEW windows (VIs front panels or BDs, no matter) from any other application on my Win7, that window will rapidly blink, or flash, 5 times.
It was just annoying at first, until lately I realized a huge problem when I needed to code.
When I try to use the quick drop, instead of placing a node on the BD, it just blinks the BD window 5 times, and the node is discarded!
I've played with windows 7 themes, and initially switching back to Basic theme helped, but now it does the same.
Any ideas how to fix?
11-25-2014 08:47 PM
Is LabVIEW the only application that is behaving oddly?
11-25-2014 11:21 PM
I ran into a wierd one a while back and it turned out to be a Teamviewer "feature" . Try rebooting your computer with nothing running in the background and see if you still have the issue.
11-26-2014 11:46 AM - edited 11-26-2014 11:47 AM
Billko: Yes, LV is the only app that behaves this way.
11-26-2014 11:50 AM - edited 11-26-2014 11:51 AM
Zwired1: I rebooted my PC several times since this weird behaviour started. I did not check if LV behaves this way when it's the only app running (which is not exactly true, even if it's the only visible window), but in any case, I have to work with many apps at the same time, so a solution ih highly desired 😞
And yes, I know, full reinstall might help, but i'd like to leave it as a last resort...1st I will check if I have a rstore point somewhere in the past, but even that will be painful.
Best to all
P.S. I do not have TeamViewer.
11-26-2014 01:30 PM
Do you use UltraMon? If so, go ot options and Compability, then add LabVIEW as exeption with "dont use windows buttons" option enabled.
11-26-2014 01:36 PM
AdamTrojak: You are da man!!! Who would think? 🙂
Thanks a lot, buddy!
11-26-2014 01:38 PM
had the same problem;) Glad I could help;)
11-26-2014 02:47 PM
Yes TeamViewer has a Quick Connect mode that adds a button to the title bar. Basically any program I've seen that messes with your title bar by adding buttons, tends to do so in a very hacky way which doesn't always play nice with other UI features.
http://forums.ni.com/t5/LabVIEW/Super-Quick-Drop-Fails-Me/td-p/2833156
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
