Reply
LabVIEW print data by using DOT MATRIX printer?
Go to Solution
How to program in LabVIEW such that certain data can be printed out from dot matrix printer?
p/s : The dot matrix printer(EPSON-TM - U220) is connected to computer via serial port.
Thank you very much for replies...
Message 1 of 6 (982 Views)
Reply
Re: LabVIEW print data by using DOT MATRIX printer?
You use VISA functions to communicate with the serial port.
Search the example finder for "serial".
Message 2 of 6 (981 Views)
Reply
I coudn't run my serial examples in LabVIEW although I have connected the dot matrix printer to my computer.
Message 3 of 6 (947 Views)
Reply
What do you mean?  Did you get an error message?  Did the PC crash?  Did the printer go up in flames?
Message 4 of 6 (944 Views)
Reply
Accepted by topic author KitChongYue
‎08-27-2015 06:09 PM
I found the solution~
preset the dot matrix printer as dafault printer and use an icon in LabVIEW called - Easy Text Report will do.
=) Thank you very much for your reply!
Message 5 of 6 (933 Views)
Occam's razor.
Ben
Senior Automation Systems Architect with Data Science Automation LabVIEW Champion Knight of NI and Prepper LinkedIn Profile
Message 6 of 6 (909 Views)
Reply
