07-16-2012 03:52 PM
Have you tried recovering a much older version of the VI?
07-17-2012 12:30 AM
Hi RMathews,
Will you please help me for same..
I got the same LabVIEW LOAD ERROR 3 : Couls not load the front panel
I have tried all mentioned steps but didnt found any success.
Please help me for same...Waiting your reply.
just ignore subvis if any....
Thanks in advance....
07-17-2012 01:56 AM
thats the problem, i havn't a much older version of my vi. only a very old version.
07-17-2012 03:33 AM
Hi there,
I tried to fix some of the vis. I hope its working for you!
Cheers, RMathews
07-17-2012 03:38 AM
and another one
07-17-2012 04:16 AM
thanks a lot, you are great! how you do this?
07-17-2012 04:21 AM
Hi evolet23
you can solve the problem in LabVIEW 2011 SP1
Instructions to fix a corrupted VI in 2011 SP1.
1. Close LabVIEW
2. Add connPaneRecoveryMode=True to the LabVIEW.ini file
3. Open the corrupt VI.
4. Push Ctrl+A on the block diagram and the copy and paste to a new VI.
5. Save the new VI.
6. Close LabVIEW and remove the ini token (VERY IMPORTANT)
7. Restart LabVIEW and load the new VI and verify it is correct. Save
07-17-2012 05:03 AM
Lots of thanks sir....
It saves my 2 days work.....
07-17-2012 05:21 AM
i tried this, but it didn't work.
07-17-2012 05:32 AM
did you try it with LabVIEW 2011 SP1?
