09-10-2014 03:04 PM
In my case, the code (front panel included) was working properly until I tried to change the connector pane. The next time I tried to open the file, it would not load. So I know it has a front panel - the problem everyone seems to be having is with the connector pane getting corrupted somehow.
If someone could help with my attached file, that'd be great. Thanks.
09-18-2014 04:56 AM
Good day!
I use Labview 2014 patch 1
After the usual save and exit the file .vi longer open, writes an error:
An error occurred loading VI 'KM_200.vi'.LabVIEW load error code 3: Could not load front panel.
Please help restore .vi file
09-18-2014 05:30 PM
@mnml_mouse wrote:
Good day!
I use Labview 2014 patch 1After the usual save and exit the file .vi longer open, writes an error:
You should probably start your own topic since this one was marked as solved. You'll get more responses that way.
10-11-2014 05:08 AM
mnml_mouse started it's own thread here…
12-11-2014 09:14 AM
I've had the problem described in this thread using Labview 2011. I tried modifying the .ini file but with no luck, please help!
My vi is attached
12-23-2014 05:54 AM
If you use the 2009 version of labview, your problem solution refrence is described in the blow link:
http://www.ni.com/download/labview-development-system-2009/1542/en/
Sincerely
Shahsavari
03-16-2015 08:06 AM
Hi.
How can I open and run 2011 Labview VI's in Labview 2014 upgraded version. I need a help regading this. shooting an error 10 code, I am not able to run and load it.
thanks in advance,
Chethan
03-16-2015 08:11 AM
do you use copy.vi? please post a screenshot from the error
03-16-2015 08:26 AM
Thanks for your reply.
I didn't save error screen shot. Will post it if I face in future.
I have to start from begining again, currently my system has 2011 version and upgrading it to 2014 Labview Full Development vesion.
Can you give me step by step to procedure to run/update 2011 VI files in 2014 version. So that I should not loose original VI's.
Help me
Thank for your response,
Chethan
03-16-2015 08:46 AM
The more recent version of LabVIEW can open the VI, but there is no guarantee that the VI will run properly without editing. Please check the upgrade notes for the version of LabVIEW you are trying to upgrade to for more information.
Did you get the following error message "LabVIEW load error code 10: Version of VI is too old to convert to current LabVIEW version
