LabVIEW load error code 3: Could not load front panel
my colleage has a problem after updating to LV2011 (from 2010) and now get:  LabVIEW load error code 3: Could not load front panel
Same on my system (also tried a mass compile)
He's afraid of loosing some of his work ..
Zipped Folder is attached
Spoiler
To the sound of a Beatles song: Yesterday, all those backups seems a waste of pay ...
Greetings from Germany
Henrik
LV since v3.1
Message 1 of 176
(16,697 Views)
µ
"Should be" isn't "Is" -Jay
Message 2 of 176
(16,690 Views)
@JÞB wrote:
µ
Henrik
LV since v3.1
Message 3 of 176
(16,684 Views)
Accepted by topic author Henrik_Volkers
Hi Henrik,
It should work now.
Instructions to fix a corrupted VI in 2011 or higher:
1. Close LabVIEW
2. Add connPaneRecoveryMode=True to the LabVIEW.ini file (-The LabVIEW.ini file is located in the National Instruments folder>>LabVIEW 2011>>LabVIEW.ini)
3. Open the corrupt VI.
4. Push Ctrl+A on the block diagram and the copy and paste to a new VI.
5. Save the new VI.
6. Close LabVIEW and remove the ini token (VERY IMPORTANT)
7. Restart LabVIEW and load the new VI and verify it is correct. Save
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 4 of 176
(16,674 Views)
Great 🙂
Thank you.
Henrik
LV since v3.1
Message 5 of 176
(16,667 Views)
Hello to all,
I have also a vi that return that error. What can I do?
Thanks to all!
Software developer
www.mcm-electronics.com
PORTUGAL
Message 6 of 176
(16,560 Views)
Can you post it? Which version is ist?
Cheers, RMathews
Ramona Lombardo
Message 7 of 176
(16,551 Views)
You can see the .vi in attach.
Software developer
PORTUGAL
Message 8 of 176
(16,549 Views)
Here you have it! 🙂
RMathews
Ramona Lombardo
Message 9 of 176
(16,536 Views)
Thanks Mathews,
But what can I do next time this happens. The only solution is sending to you?
Thanks for your help!
Software developer
PORTUGAL
Message 10 of 176
(16,530 Views)
