09-19-2014 01:50 AM
Good day!
Decided to use the new version of LabVIEW 2014 patch 1!
Week everything was fine and suddenly, after the usual save and exit LabVIEW 2014 ceased to open the main .vi file:
Writes an error:
LabVIEW Generic error:
An error occurred loading VI 'KM_200.vi'.LabVIEW load error code 3: Could not load front panel.
Copies of this .vi certainly did, and worked on it for 6 months!
Please somebody help with the restoration of the file!
09-19-2014 02:05 AM
10-11-2014 05:06 AM - edited 10-11-2014 05:06 AM
10-11-2014 05:25 AM
you asked me for another copy of the draft, I thought you could help me restore that file KM-200.vi
10-11-2014 05:30 AM
no, I didn't ask you to send your backup to me! You should just use your backup to restore the screwed file…
Your backup seems ok, I could open all the VIs. You should clean up the code anyway, refactoring seems a good idea too…
10-11-2014 07:40 AM
but how can I restore the attached file KM-200.vi ?
10-12-2014 12:47 PM
11-16-2014 02:16 AM
I have the same problem. How can I fix this ?
Would somebody help me?
I attached my crash vi
11-16-2014 09:55 AM
