LabVIEW communication on Ad hoc wireless connection
Step 1: Ipconfiguration of pc
Step 2: Ip Configuration of Tablet
Step 3: netstat of pc
Step 4: netstat of tablet
Step 5: pinging tablet ip from pc
Step 6: pinging pc ip from tablet
Step 7: running server vi
Step 8: running client vi
Message 11 of 13
(887 Views)
Guys a little help would be appreciated
Message 12 of 13
(857 Views)
If you change the port number, you need to change it on both the client and server.
I still think you have a firewall issue which is blocking the client from connecting to the server on the port you are using. I would try adding TCP port 139 to your firewall exceptions list and/or try disabling the firewall on the specific connection (which sometimes does something different to just turning off the firewall). Maybe you have multiple firewall programs installed?
In any case - it's a network configuration issue rather than a LabVIEW one so I suggest you talk to some IT guys.
(blog)
Message 13 of 13
(823 Views)
