04-30-2017 03:02 AM
I have been using LabVIEW from 2014, upto now I never bothered about this issue but now I wanted to place a component there so it is an issue.
I currently have LabVIEW 15.0f2 (32-bit) running on Windows 10 updated to KB3150513 Windows update. So the front panel has a little LabVIEW signature at the bottom-right corner. It looks like [please refer temp.png (attached)]. My software is activated with a student license (not the 6 month thing, but permanent). This really interferes and confuses the user if I place a button on the bottom-right corner of the window.
Does anyone know how to get rid of this??
Thanks!!
Solved! Go to Solution.
04-30-2017 10:21 AM
You can get rid of it by purchasing a more expensive license, either basic, full, or professional development system.
04-30-2017 11:55 AM
You can also make the window a little larger vertically, so the watermark does not cover any of your front panel objects.
(The watermark indicates that you are developing in a LabVIEW version that is not licensed for commercial use. It is part of your development environment and will not show if the same VI is opened in a commercial version that is orders of magnitude more expensive.)
05-08-2017 07:18 AM
So I guess I can't do much without paying more. However, your answer has cleared the things to me
Thanks, altenbach!!
Anuj
