LabVIEW Runtime Engine 2009 Installer Runs at PC Startup
As of a few weeks ago, upon startup of my PC the installer for the LabVIEW Runtime Engine 2009 immediately opens, fails to locate the installation files, and hangs. Performing a proper installation of this software does not resolve the issue.
I'm currently running LabVIEW 2014 SP1 as my main development environment with no issues aside from this one. Can anyone please provide assistance?
Message 1 of 9
(3,272 Views)
Message 2 of 9
(3,269 Views)
What happened a few weeks ago that caused your PC to behave differently?  Did you add any software?  Uninstall any software?
What does Multi_CALPGA309 (Installer) mean to you?  Is this any project you were working on?
Is there anythink in Windows registry or MSConfig startup or anywhere else that would cause some installer to begin running automatically on startup?
Message 3 of 9
(3,251 Views)
Hi RavensFan, I've installed one piece of software that I can think of in that time, Designsoft TINA v11 which is unrelated to any NI software. The Multi_CAL software is a project I've worked on in the past.
All the NI startup items were disabled in MSConfig as part of my own debug.
Message 4 of 9
(3,243 Views)
Can you contact them?  Is it possible that that software was written in LabVIEW, but you don't know it?  What if you uninstall that?
Message 5 of 9
(3,232 Views)
I think MSconfig does not list Start -> All programs -> Startup shortcuts. Check that place also.
Can you figure out from where does it run the 2009 installer?
Message 6 of 9
(3,230 Views)
Hello RavensFan, I can confirm that TINA was not written in LabVIEW. The issue also did not appear immediately after installing it, it's just the only major software I can recall installing recently.
Message 7 of 9
(3,209 Views)
Hello Alexander, thank you for the suggestion. The only thing in my Startup shortcuts folder is a free World Clock utility from Wim's Programs.
Message 8 of 9
(3,208 Views)
Accepted by topic author leto_II
Completely uninstalling all NI products and reinstalling LabVIEW resolved the issue.
Message 9 of 9
(3,146 Views)
