01-04-2017 12:06 PM
As of a few weeks ago, upon startup of my PC the installer for the LabVIEW Runtime Engine 2009 immediately opens, fails to locate the installation files, and hangs. Performing a proper installation of this software does not resolve the issue.
I'm currently running LabVIEW 2014 SP1 as my main development environment with no issues aside from this one. Can anyone please provide assistance?
01-04-2017 12:10 PM
01-04-2017 12:23 PM
What happened a few weeks ago that caused your PC to behave differently? Did you add any software? Uninstall any software?
What does Multi_CALPGA309 (Installer) mean to you? Is this any project you were working on?
Is there anythink in Windows registry or MSConfig startup or anywhere else that would cause some installer to begin running automatically on startup?
01-04-2017 12:29 PM
Hi RavensFan, I've installed one piece of software that I can think of in that time, Designsoft TINA v11 which is unrelated to any NI software. The Multi_CAL software is a project I've worked on in the past.
All the NI startup items were disabled in MSConfig as part of my own debug.
01-04-2017 12:48 PM
Can you contact them? Is it possible that that software was written in LabVIEW, but you don't know it? What if you uninstall that?
01-04-2017 12:50 PM
I think MSconfig does not list Start -> All programs -> Startup shortcuts. Check that place also.
Can you figure out from where does it run the 2009 installer?
01-04-2017 01:17 PM
Hello RavensFan, I can confirm that TINA was not written in LabVIEW. The issue also did not appear immediately after installing it, it's just the only major software I can recall installing recently.
01-04-2017 01:19 PM
Hello Alexander, thank you for the suggestion. The only thing in my Startup shortcuts folder is a free World Clock utility from Wim's Programs.
01-26-2017 12:15 PM
Completely uninstalling all NI products and reinstalling LabVIEW resolved the issue.
