07-20-2016 08:43 AM
Is there a way to control and monitor a VI remotely via internet (not via local network)?
I used the remote panel but I only can monitor the VI in a local network. I have a website domain and i want to display my VI on it.
Thank you.
07-20-2016 08:58 AM
Do you have access to your servers? If you can load LV onto the servers (like with AWS for example), you can run whatever you'd like on that system with it. You'd use the same methods you've been using to get it on your network. You'd just run it with the public facing IP.
