07-13-2017 10:08 PM
I have my labview vi control panel and block diagram panel printscreens (labview 1,2,3 and 4) with the Labview Interface for Arduino The Labview is the receiver while the Python code(3d hand tracking) is the sender through UDP. Whenever the python send sets of angles,take note that the angles are varying in some fractions of time, the labview with the arduino and servos connected didnt actuate according to the varying time of the sender ..the servos wait 1 sec to actuate and this is very slow compare to the real varying time of angles from the sender ..this is our problem..
Thanks for the help!
07-14-2017 01:26 AM
07-14-2017 05:25 AM
What are the other event cases you are handling with the Event Structure. You might be able to not even have the Event Structure and simplify your diagram, but that depends on what the other cases do.
As Gerd already stated, that 100ms wait is not needed. The other concern I have is the Wait Forever on the UDP Read. That will lock up your program if data is not being sent by the other system. Set the timeout to be 100ms and handle any errors you see.
07-19-2017 02:04 AM
Good day .. I have modified the block diagram ..but the output is still the same.. Hope you can help me ..See the printscreen .
07-19-2017 02:11 AM
07-19-2017 02:46 AM - edited 07-19-2017 02:56 AM
Thanks for the help sir .. The Python sends sets of angles(angles of yaw,pitch and roll) to the Labview in some factions of seconds .. but the servos waits 2 seconds to actuate every angles ,one after another which is very slow..But ,whenever I remove the arduino from the pc, the labview graphs angles with respect to time accurately ,which is the ideal output .Hope you understand .I'll wait for your response guys and thank you in advance!
i have provided a video but I saved it using my facebook account..you can visit
Fist video : the arduino is connected
https://www.facebook.com/EuNico105/videos/vb.100002514763187/1405209926239486/?type=3&theater
2nd video: the arduino is not connected
https://www.facebook.com/EuNico105/videos/vb.100002514763187/1405214186239060/?type=3&theater
07-19-2017 02:56 AM - edited 07-19-2017 02:59 AM
Hi Audrey/Eugene,
unfortunately Facebook is blocking access to your videos - atleast for non-members…
At the second try the video was visible. You really need to improve the video quality…
So your VI is getting slow whenever you communicate with your Arduino? And is runs fast without that communication?
So I see two things:
- Arduino communication is maybe slower than you would think.
- You may try to use some kind of producer-consumer-scheme to separate faster processes from slower ones…
07-19-2017 03:05 AM
Im sorry for the low quality video sir .. Hope you see the graph and values
Can you help me with this??
--You may try to use some kind of producer-consumer-scheme to separate faster processes from slower ones…--
07-19-2017 03:22 AM
07-19-2017 03:39 AM
Thanks GerdW for the help but what is the significance of this producer-consumer concept to my problem? Thanks for the help !
