LabVIEW, GPIB-USB-HS
Open MAX to play with your GPIB card & the instrument under control. This is to make sure the connection, configure, commands, data communication etc are all properly set.
Then you'll have this type of issue solved. Good luck.
Be True!
Message 11 of 19
(558 Views)
Thank you for the suggestion. I will try
Message 12 of 19
(544 Views)
How do I do that step sir? I am now using the NI GPIB again.
Message 13 of 19
(523 Views)
I am getting an ERR 6 message
Message 14 of 19
(516 Views)
is meas:vav? an oscope command or multimeter command?
Message 15 of 19
(513 Views)
You simply need to look up the command in the manuals.
Message 16 of 19
(505 Views)
Thank you
Message 17 of 19
(499 Views)
screen shot of error
Message 18 of 19
(497 Views)
Hi AM33,
Could you please add a Simple Error Handler at the end of your VI so we can see more information on the error? Please try increasing the timeout value on your GPIB Write.
The GPIB Write command will be specific to your devices. Please try looking through the device manuals to determine what this command should be doing.
Thank you,
Emily C
Message 19 of 19
(479 Views)
