01-12-2016 05:03 AM
Hello to all,
I am studying on FPGA and DMA transfer.
I would like to create square wave from FPGA.vi and show it on Host.vi
For this, I created attached vi diagrams. I have problems on signal correctness.
According to the problem, I attached the signal results on 250k frequency and 10M frequency.
My electronic device is sbRIO9606.
Where is the error? And, how should I correct my error?
Please, help me find it out.
Thank you.
01-12-2016 07:01 AM
A small help can be very good, please
01-12-2016 08:26 AM - edited 01-12-2016 08:27 AM
Your subject title is "LabVIEW FPGA" which is not very descriptive. You posted pictures of your code, not the actual code. And you waited only 2 hours before bumping the thread adding no new information, these are all examples of bad etiquette. (Unofficial Guidelines)
Did you search the example finder? Because if you go to Help >> Example Finder, and search FPGA Wave you'll find there is a Square Wave example. Your frequency seems a bit high, at lower frequences does it work properly? Do you have a scope to see if the output is correct? Do you have a frequency generator to see if the input is correct?
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
