05-29-2015 09:13 AM
Don't use the mdb provided with the Labview examples for your own database. Create your own MDB file, save it with your project and link up to it using a connection string like the one below. You'll need to modify the string to include the correct path.
05-29-2015 02:28 PM
Can anyone makes sense of this error message. On the target system (in Germany), the LabVIEW EXE and the LabVIEW.udl are in the same directory. But nothing works until I put the LabVIEW.mdb in the c:\program files(x86)\National Instruments\LabVIEW 2011\examples\database.... WHY?
And then I get this error message (attached). The German in the error message roughly translates to: "Operation must use an updateable query" when I use the insert in to table vi.
Steve
05-29-2015 02:32 PM
Are you actually reading any of the posts in this thread?
05-29-2015 02:34 PM
Have you looked up the error code?
05-29-2015 02:53 PM
On a development system, the files that you are using are located in the examples directory (see below pic). On a deployed system, those files (mdb and udl) do not exist because they are example support files. You can create your own or copy them to the same path on the deployed system as they exist on the development system. That is the reason i told you to create your own mdb and udl file and put them in your application directory so that your exe isn't tied to system examples.
05-29-2015 02:57 PM
Edit the udl file in a text editor and you will see why it is looking in that particular directory for the MDB.
05-29-2015 03:02 PM
Now if you had read the above post, you could have solved your problems by eliminating the Get UDL Path vi and replaced it with this code. Using this bit of code, you can eliminate the need for the Get UDL Path vi and the UDL file. You would only need the MDB file placed in a directory and the path to the MDB file typed into the string constant (with quotes around the path).
05-29-2015 03:19 PM
Suddenly, I am getting all of the responses at once. Let me digest this and see if I can make sense of this.
MANY MANY THANKS.
Steve
