@X. wrote:
I am referring to uninitialized shift-register, obviously. And in most of my use case, there is no space for a wire label inside the llop, as the wire goes straight into a state machine (or more generally a case structure).
I allowed for unintitialized shift registers when I mentioned labeling the wires - obviously. And we have different coding styles, which is why I specifically mentioned that in my case, I don't worry about attaching labels to my shift registers.
I think it's just a matter of preference. I prefer my labels inside the loop. Your preference is outside the loop. I can see why, too. It saves horizontal space because it cuts out one area where you have labels. Still, wherever possible, I like to have my wires identifiable simply by mousing over them. (Admittedly, my wire label strategy doesn't work with pre- "wire labels as property" LabVIEW versions.)
Bill
(Mid-Level minion.)
Humble author of the
CLAD Nugget.
