LabVIEW 2016 Runtime menus Problem
I have made a small program to demonstrate custom made runtime menu. But it seems I am having a problem. I have tried configuring several things on the respective subVIs Windows Appearance and Excecution which are set from the VI properties. Also, I have configured call set-up and subVI node Setup appropriately but I seem not be getting what I need.
During the runtime, I would like to open up the respective subVI by navitating through the Host VI menu while it runs. Secondly, I would like to recal the same subVI more than ones.
How can I accoplish this? Any suggestions will be highly appreciated. Thank you.
I am using LabVIEW 2016. My VIs are also attached to show what I have done.
Kind Regards,
Opuk
(2,621 Views)
Hello Opuk,
please check the names and stettings, also use a asynchron call for running the VI´s. Attached the modified example.
best regards
Alexander
(2,552 Views)
