04-01-2014 02:01 AM
Hello all,
I have a question regarding the Bug 425800 (Quit LabVIEW will not quit if the event 'Application Instance close' is present) in LV2013. According to NI this Bug is fixed in LV2013 SP1.
I have an application, which was converted from LV2011. The application compiled in LV2011 worked well.
After converting to LV2013 I had the issue, that the exe won't quit. I updated to LV2013 SP1 and mass compiled my project. After building the executable again, I have the same issue. My compiled EXE (LV2013 SP1) will not quit.
One VI contain the 'Application Instance close' event, because the PC is connected to an UPS and the application should be terminated in a save way in case of power loss.
Is there any other reason why the 'Quit LabVIEW' will not work?
As a little reminder: The application worked well in LV2011.
Regards
Heinrich Eidloth
04-02-2014 06:46 AM
Dear Mr Eidloth,
I would like to help you resolve this issue.
Would you mind sending me your program to look into so I can help you better?
Alternatively you could try running the added example to test the functionality of the "Application Instance close" Event and the "Quit LabView" funktion.
Thank you very much in advance.
Best Regards
Veronika Kurz
04-02-2014 07:32 AM
04-02-2014 07:40 AM
Hello Mr. Eidloth,
that would be great. Thank you very much.
Regards
Ms. Veronika Kurz
04-02-2014 08:31 AM
04-02-2014 08:34 AM
again with attachment (i hope)
04-02-2014 08:44 AM
Thank you very much. I will look right into it and keep you updated about the progress.
Regards
04-03-2014 06:34 AM
Dear Mr. Eidloth,
I tested the program you sent and asserted that it works properly on my computer using LabView 2013 SP 1.
Now my question: Did you modify any settings?
Would it be possible for you to send me the MAX-Report?
Thank you in advance.
Regards
04-03-2014 06:56 AM
Hello Ms. Kurz,
no, I didn't change any settings. I only mass compiled the project.
What do you mean with MAX-Report (uups)?
Regards
Heinrich Eidloth
04-03-2014 07:21 AM
Hello Mr. Eidloth,
you can find the Report in the National Instruments Measurement and Automation Explorer (short MAX).
If you can't find it on your desctop open the Explorer and browse C:\Program Files (x86)\National Instruments\MAX.
Open the MAX -> File -> Generate Protocol (or something along the lines of it, I am sorry but I had to translated it from the German version so I´m not exactly sure) ->Continue -> Protocol for technical support -> Continue -> Choose a path for the file ->Generate.
Please don´t hesitate to ask further questions.
Regards
