01-24-2011 01:42 PM
Interesting LabVIEW 2010 "feature" I discovered this morning.
Attached are two identical VIs, one saved in 2010 and one saved in 2009. These VIs were specifically written to demonstrate the bug I stumbled upon this afternoon. Each VI when run should allow you to find a specific program (window) open in Microsoft Windows and bring it to the foreground. It relies on "user32.dll" to perform this operation. It also allows you to specify the calling convention for the function call.
In LV 2009, either calling convention works, without error. However, in LV 2010 the calling convention for the function must be "stdcall (WINAPI)" and not the default "C". If the calling convention is "C" then LabVIEW crashes and closes without warning.
If you happen to have both LV 2009 and LV 2010 on your computer, I would love to hear if this phenomenon is duplicated so that I can pinpoint whether the bug is LV 2010 related or is more specific to my personal setup.
~David
Solved! Go to Solution.
01-24-2011 02:45 PM
There has been several instances of this documented over the last few weeks as we all are migrating over to 2010. This has something to do with the fact that previous versions of LabView fixed issues in calling convention that are not checked (due to compiler optimization in 2010, at least the current explanation) in 2010 and cause a crash. I guess this is not really a bug but an inconvenience. I will post links if I find them.
01-24-2011 02:47 PM
221113 Return |
CLFN with the wrong calling convention may siliently crash LabVIEW. LabVIEW 8.5 through 2009 could adjust the calling convention at run time if the user selected the wrong option. In 2010 this no longer happens. More information is found in KnowledgeBase 59KB14WI Workaround: Use the correct calling convention
From 2010 release notes.
01-24-2011 02:53 PM
Thanks for the response Paul. Glad to see it's a known issue. Rather unfortunate that it yields a silent and complete LabVIEW crash, but at least now I understand why and the workaround is simple .
05-05-2017 06:38 PM
