04-25-2013 09:31 AM
We have been doing some new LabVIEW development. We started turning them into executable. Errors occurred during the build in a File I/O vi. This was resolved by copying the diagram into a new vi. This seemed odd given that it was the same vi. Any thoughts on this?
There are problems with the program operation once we create and run the .exe. The vi runs fine. Hum? Some of the issues are...... (1) some of the setup .vi for our test equipment no longer setup the equipment correctly (2) sub .vis that were set to show must be set in the vi properties of the vi instead of in the calling vi. I've read that the executable run quicker than the vi. ....most of our communication to instruments is through GPIB. Are there any suggestions on how to control timing when using GPIB?
THANK YOU!
04-25-2013 09:41 AM
Why can't I run an executable created in LabVIEW 2009 and later, and how do I fix it?
Theres a good KB article that should set you straight.
