12-18-2013 08:21 AM
While revising the documentation of a VI, I faced a LabVIEW crash. I can reproduce it in LabVIEW 13.0f2 with the following code. Can anyone confirm that cutting the content "def" from the free label and trying to paste it in the free label with "ghi" produces error 0xBC0BF185?
I cannot reproduce this issue by any other cut/paste between the free labels on the left-hand part of the BD. The crash solely occurs when cutting "def" and trying to paste to "ghi".
12-18-2013 09:11 AM - edited 12-18-2013 09:23 AM
I'm not reproducing it from the snipette. LabVIEW 2013.0f2x32 on Win7 enterprise. Heap Peek your copy, there is something insane with your label.
Whoops.... I take that back.
Crash report sent- d77e8fae-e15f-45d7-9bc5-d125970a4119
12-18-2013 09:21 AM
Thanks for confirming, Jeff.
I didn't do any Heap Peak until now. I did not expect any insane object because I actually created just the topmost free label. The other instances were created by copy and paste from this free label.
12-20-2013 09:01 AM
Heap Peak seems the way to use, to deal with this.
01-02-2014 02:32 PM
Hello all,
I looked into this, and it is more general than just the insanity in the label. I filed CAR 442743 for this behavior. It is a crash that can occur when cutting and pasting text between free labels in LabVIEW 2013 with the auto tool turned off. This is related to CAR 408955 (crash occurs when deleting a comment with auto tool turned off) which was fixed in the LabVIEW 2013 f1 Patch. This case was not covered by that fix and will be fixed in a future release.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
08-21-2014 03:00 PM
CAR 442743 discussed in this thread was fixed in the LabVIEW 2013 SP1 f2 Patch, and in LabVIEW 2014. For a more complete list of bugs fixed in LabVIEW 2014, check the LabVIEW 2014 Bug Fixes. You can download an evaluation copy of LabVIEW 2014 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
